Barry777
Mar 11, 2010, 1:57 PM
Post #4 of 4
(1790 views)
Re: [philinchio] VCR has issues playing certain tapes.
With any GOOD VCR (manufactured before 1990), my first step is always to recap the power supply board - this fixes a lot of problems before I touch any adjustments, etc. Especially with switching-type or resonant-mode power supplies, cap values are very important as they are parts of oscillators rather than acting as simple filter like in the old fashioned transformar/rectifier/filter arrangement. The faulty caps are usually not the largest ones; from my experience the ones that are low cap/high volt (such as 1 uF at 50 volts) are the first ones to break down. I would replace all the smaller ones, then move on to the bad boys if that doesn't fix the problem. True, it could be a capstan servo issue - but it's more likely to be caused by the power supply than in the capstan servo system itself. I would think a worn pressure roller would also cause trouble on the other speeds, but it is a possibility as the EP speed is the most critical. If there's a seperate capstan free-run adjustment for EP speed on the circuit board, might try slightly adjusting that AFTER replacing the power supply caps. Not a good idea to mess with adjustments before recapping, or you'll end up with a machine with good caps but is now out of alignment. If you're not into electronics, it's best to let a professional handle it - this isn't dirty heads or anything else that can be tackled the layman or a few pieces of test equipment. If you know an excited kid with a soldering iron, he can probably replace the caps - but I wouldn't go any further than that. . . . Barry Fone - VCR Repair hobbyist and professional FAA Repair Station Avionics Bench Technician (top level). TEST EQUIPMENT: (4) Sencore VC93 VCR Analyzers, (11) Tentel gauges, Sencore VA48 and (2) VA62 Video Analyzers, Sigma Electronics TSG-375 NTSC/SMPTE Video Generator, several VCR Alignment Tapes, plus countless Oscilloscopes, Frequency Counters, Wow and Flutter Meters, Distortion Analyzers, Vectorscope, 136-channel Logic Analyzer, Signature Analyzer . . . . VIDEO GEAR: (6) JVC BR-S822U's, (3) JVC BR-7000 series, (3) JVC BR-S500U, (2) JVC BR-S800U, JVC GR-800U and (2) GR-860U Editing Controllers, Sony FXE-100 Video Switcher/Effects Generator, (5) Time Code Generator/Readers, (1) Sony SLO-1800 (Beta), (2) Alesis ADAT-XT, (1) Sony DXC-1200 TV Camera, Pioneer VP-1000 Laser Disc Player plus many consumer grade Beta and VHS VCR's. Passionate electronics enthusiast since 1973...most anything except computers. Check out my collection at www.barrys8trackrepair.com/MyVideoGear.html
