streetsounds
Jan 8, 2007, 11:44 PM
Post #3 of 3
(15816 views)
Re: [daggazz] Pioneer Plasma PDP-434PU Media Receiver?
Hi Daggazz, yes the Plasma will work fine alone without Media Receiver. Plug the Plasma into a DVI port of a PC/Laptop for example and it will work. I am running a Pioneer Plasma of a Divx Media Box/Laptop and it works fine. Just make sure you power up your source unit before turning on Plasma otherwise it will turn off again and will flash Red and Green squares on the screen. If the picture is not in sync just adjust it like you would adjust the resolution on the Computer. If your Computer or Laptop has no DVI out you can use this item availbale at NewEgg to adapt VGA out to DVI 14-999-504 VGA ADAPTER DVI-CRT DVI F / HD15 $3.99
(This post was edited by streetsounds on Jan 8, 2007, 11:53 PM)
