Jan 23, 2011, 7:01 PM
Post #12 of 16
(5293 views)
Re: [kjones9999] PTK 195 Convergence Power Supply Question
kjones9999;..... I have the first three but no advanced. Houston , you have a problem..... BTW , are you using the original remote ???? If I reversed green with red, and tested the results in the convergence menu could this hurt anything? The connectors should be the same...Short answer , no.... Your pix WILL change because the red , green & blue convergence pulses ARE different... So be suprised at what you see , but not shocked.... Looking at the schematic this seems like it could help determine whether this is a problem on just the green circuit or a broader issue. I don't know what you mean by "broader issue"... What you are doing is switching the intentional distortion that the convergence circuits develop for each color (from red to green).... You may not see any results due to the fact that the green is in the center of the rack & the red is on the outside of the rack.... This means that since the green is in the center , little modification of the pix is needed to get a square undistorted pix on screen (Optics)... Since the red (& blue) is off to one side , the angle of the pix getting to the screen is different than the green , hence more intentional distortion.... IF you were to remove the screen & take a look DIRECTLY at the pix on the CRT face thru the lenses , you can actually see the distortion... I'm not sure the results will prove anything.... Do NOT try to adjust the red/green convergence after you switch the connectors... Reason is that when you switch back , you will have an even bigger mess than when you started... I'n going to stick my neck out here & ask you to try something.... On page 5 (to the right of "C") in the manual is the "Service Menu & Digital Convergence" adjustments.... IF , and I repeat , IF you feel comfortable doing this , follow my instructions to the letter.... I'd like to see IF you get the crosshatch mentioned in the Digital Convergence proceedure.... What I'd like you to do is get into the Digital Convergence part & check for the crosshatch & LEAVE WITHOUT adjusting ANYTHING !!!! Are you up for that ???? IF you tinker with ANY of the adjustments , you WILL Screw up things for the new board.... The adjustments are NOT stored in or on the convergence board.... They are stored in the eprom which is a different part of the set...(Micro circuitry)... GOOD LUCK......... Later....Ron.M........ Veteran & Retired TV technician
(This post was edited by Ron.M on Jan 23, 2011, 7:16 PM)
