Jan 14, 2013, 8:52 PM
Post #2 of 4
(2201 views)
Re: [chadreg] Philips 55PW9363 - Convergence Problem
chadreg;.... How do the red & blue line up ??? You apparently inadvertently did not do the green coolant properly... This is a mechanical problem that should be relatively easy to correct... However , I would be able to give you better detailed info if you could post some pix.. Here's how;=>... How do I post pictures? I'll simplify this..... 1st , take a GOOD pix with your camera.... Upload it (them) to your computer.... Save it as a JPEG...... Save it to your desktop or ???.... Give it a name so you can find it easily.... Go to http://imageshack.us/ or http://register.photobucket.com/step1 or flickr or ??? & sign up & join.... They are all FREE to join & use.... I suggest you use imageshack as it is easier.... Upload your pix.... When you upload your pix to imageshack.com use the "Upload Options" feature.... Click on the drop down arrow where it says "Do not resize"..... Choose 800X600...Skip "Add Label"...(?)....Upload pix... When posting a pix from imageshack.us do this;... Select the pix you want to post from "My Images".... Right click on the image you want to post.... A box with several choices will appear.... Choose "View Image".... When that window opens , right click your mouse anywhere in the pix to get "copy" up in another set of options... Do NOT click on "Zoom".... Click on "copy"... Come back to the box you are posting in , right click "paste" & Ta-Da , your pix should pop up full sized & clear as it was taken... Before you post the pix in the thread , go to the "Preview Post" button at the bottom center where you are making your post & click on that one time.... Wait for it to load the post... Scroll up & check your post & pix... If the pix is too small or too big , go back to imageshack (or photobucket) & make the needed adjustments.... If you need any further help or info , just post.... PLEASE DON"T post pix we need IMAX to view.... Take clear pix of the center screen of the convergence crosses.. Use the "customer" convergence menu ONLY... Please post that one & the others you have... THANKS....... Later...Ron.M...... Veteran & Retired TV technician
(This post was edited by Ron.M on Jan 16, 2013, 8:19 PM)
