Southerner1959
Nov 1, 2015, 9:35 PM
Post #18 of 37
(6764 views)
Re: [jts1957] LED LG 55LN5710 NO VIDEO
I haven't tried taking the screen apart to get at the LED strings . . . BUT . . . I have repeatedly been turning the set on and off . . . and every time you get a full picture - it's not for a second, more like a quarter of a second . . . but that makes me think it COULDN'T be the LEDs failing. Surely it wouldn't be so repeatable? So . . . I hooked up wires from one of the pair of LED feeds . . . and as expected, there is no voltage there, except when you first turn on, and the meter kicks up momentarily (hard to guess what the voltage is, but I would guess it might be about 24V) So I guess it is the control circuitry going wrong, that feeds a signal to the switching power FET? The output of each FET goes directly to the LED Backlight feeds (there are 2 completely separate PSUs for each LED string, ie rectifier diodes, smoothing caps and a Switching FET.) What I find odd is that the DC voltage going to each FET is actually 75V . . . surprised it is that high. I managed to see the TV's backlight settings (using a flashlight on the screen) and it was set at 100% . . . tried turning it up and down a bit, but obviously made no difference) EDIT: Just had an idea . . . think I will try unplugging the Backlight lead from the PSU Board and feed some DC to it . . . presumably the screen will then light up? But what sort of voltage will it be looking for? Any idea?
(This post was edited by Southerner1959 on Nov 1, 2015, 9:44 PM)
