josegrad
Aug 24, 2015, 6:29 AM
Post #1 of 4
(1263 views)
LG LCD horizontal line and grayed out areas
Hi, I've searched the forum and found some posts about my problem. I'll be following the advices, open the TV to check inside for any loose connections and so on. But I wanted to share a picture of the problem, maybe any of you can already tell how serious the issue is. The TV model is LG 32LH300 https://s3-us-west-1.amazonaws.com/lcdforum/IMG_4036.JPG The image shows a single horizontal white line that changes in pattern a bit depending on the image on the screen. The background should be pretty much all the same color, but as you can see there are three areas. The two big areas on the bottom should not be there at all. The image is from the PlayStation but the same happens with normal TV. Thanks.
