Repair man
Jul 27, 2015, 5:03 AM
Post #3 of 3
(1999 views)
Re: [Texas Slim] LG TV 60LD550 LCD tv wont come on...Red LED Slow blink when powered on. TV stays dead.
It will likely be a problem with the power supply. The other board in that TV is the main signal board & generally if it responds to the remote (like yours is doing) then in most cases it will be OK. Given the fact that the first few times you were able to power your TV back on, it's probably just a bad capacitor (or a few bad capacitors) that have gone bad on that power supply. You can physically look at the caps & sometimes it obvious which ones are bad (bulged on top) other times caps can look totally fine but still be bad internally, which is much harder to tell. I have an ESR meter to check caps (as do most repair shops) so if you can't find the bad ones you could consider taking the board to a shop. If you can fix it yourself them by all means go ahead, it will likely save you $100 or more. If you go to YouTube there are plenty of people on there describing & showing what to look for when changing bad caps; you likely won't find your exact TV but the procedure will be the same. If not you could look for another power supply online; it would be a shame though to get another power supply if it only needs a few capacitors (probably under $10 for a few caps). . ------------------------------------------------------------------------------------------ If you (or anyone reading this post) have any further questions or need clarification please feel free to contact me direct; you can find my email address by clicking on my user-name. Learn Plasma TV Repair _________________ Learn LCD TV Repair
