dune
Apr 5, 2020, 9:08 PM
(877 views)
NEC V463 won't stay on, red light
Make/model: NEC V463 Behavior - Unit powers on, fans spin, backlight flashes, then completely powers off after ~5 seconds - This power cycle auto-repeats 3-4 times before stopping permanently - Red led on front bezel illuminates, 2 short blinks + 1 long Additional Info/Repairs Attempted (with zero change in behavior) - Replaced Power supply board 715G4390-P03-W30-003H - Replaced Mainboard 715G5737-M01-000-005I - Replaced LED driver board NEC 55.46P06.D01 - Replaced LED timing control board NEC 55.46P06.C03 - Replaced IR sensor 715G3587-T01-000-004M - Both chassis fans pass external tests Power-on video: https://www.youtube.com/watch?v=JYcIM4PbPnE I am not sure this behavior is because it is currently face-down with the back cover off. I suspect a temperature sensing problem and the unit stays on a little longer leaving the IR sensor unplugged, but already replaced the sensor. Any suggestions/leads, or a service manual, much appreciated!
(This post was edited by dune on Apr 8, 2020, 12:09 AM)
