Nov 5, 2015, 6:58 PM
Post #2 of 7
(1354 views)
Re: [Southerner1959] Size of Backlight LEDS ?
Your local recycler may be able to provide a Same brand - SIMILAR panel size model of a similar vintage, and even if NOT the same backlight technology, it would give a screen to 'practice' disassembly / assembly on/with. Be careful with the tabs as pointed out in video, they can detach with surprisingly little pressure. Try NOT to pick up the TFT glass panel by the corners. It may help to have two persons for larger screens. Bring a smart phone and research the model numbers that recyclers have to confirm backlight technology. (Edge vs whole panel array.)(Google Model number with CNET can give basic specs.) The closer the Brand, screen size and vintage, the more likely a 'match.' Just bear in mind that donor set probably has bad LEDs too. The LEDs in a used set will match the ones in your set better than brand new ones in regards to operating hours, reduced brightness, etc. Just remember to reduce the duty cycle of the LEDs. ------------------------- Location: Far, Far Away
