Aug 10, 2015, 5:23 PM
Post #2 of 27
(3815 views)
Re: [Blackbeen] Sony KDL-46V3000 will not power up
When an error occurs, the STANDBY LED flashes a set number of times to indicate the possible cause of the problem. If there is more than one error, the LED will identify the first of the problem areas. If the errors occur simultaneously, the one that corresponds to the fewest flashes is identified first. (Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a “00”) 1. TV must be in standby mode. (Power off). 2. Press the following 4 buttons on the Remote Commander within a second of each other: DISPLAY / (Channel) 5 / Volume '-' / TV POWER . The Self Check list displays. IF it is currently dead - I'd disconnect it from power strips, outputs to audio systems, etc. Leave set top box or item that was selected as Input when it failed hooked up and active. If INTERNAL 'speakers' are 'off,' as opposed to volume minimum, and you can't access Menu, that might be a problem. ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Aug 10, 2015, 5:29 PM)
