Jun 1, 2015, 9:37 PM
Post #4 of 13
(2129 views)
Re: [akoen] Technical: Panasonic Plasma 50" is clicking, but not turning on. All capacitors is replaced
1) There is a problem inside your television; 2) Change boards until TV works. If all boards are changed and problem still remains - either a board you were told was good is in fact defective or the display panel itself is involved; 3) Once the board that was preventing the TVs proper operation is determined, then you can move on to changing the likely semiconductors one at a time or all at once, then the caps. If this happens to be the board that you've already changed the capacitors on, you can skip this step. ------------------------- Location: Far, Far Away
