gilwe
Jul 1, 2007, 9:38 PM
Post #10 of 29
(16025 views)
Re: [techchris] how to eliminate high voltage leakage from flyback ?
Sure... I don't care at all about replacing the FB, I just wanted to make sure the the FB wrong behaviour is indeed because the FB is bad, and not because some other bad part driving it bad... So what do you say ? any procedure to verify that the FB is indeed bad, before oredering a replacement ? Also, btw, would you recommend ACME replacement FB for Sony ? or do I go wrong here, and should get an original Sony FB ? Also, as I said the arcing is not at the flyback itself, but at the tube that is on the box (high voltage block?) which is attached to the chasis, to which the FB cable is connected , and from which the anode goes to CRT. So, is the FB defected or is that block defected ? Is that box an integral part of the FB and I should expect to get the FB with the box and all wires, in case I order a replacement FB? Thanks all for your help !
(This post was edited by gilwe on Jul 1, 2007, 10:35 PM)
