Sep 4, 2015, 1:38 AM
Post #6 of 8
(1247 views)
Re: [regent] magnavox crt tv dead
Bear in mind that that may or may not be exact to your set. Also bear in mind that we are only privy to your WRITTEN/POSTED words. We can't read minds. You give symptom - we give location of bad part. On the newer sets, that might work down to board level. On these older sets we should be able to troubleshoot to the exact part(s) that are defective. We are here - You and your set are there. You have to be our eyes, ears, hands, etc. We ask questions, suggest tests and measurements - you have to make them and report back with the results. We may start out in one direction and then proceed in a different direction based on test / measurement results. We know how to take these measurements. What function meter is set to, which range, where/how to place test leads, etc. The time to ask for clarification is BEFORE taking and reporting measurements. Google can also provide 'how to test ____.' ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Sep 4, 2015, 1:38 AM)
