Barry777
Jul 17, 2010, 3:02 AM
Post #9 of 9
(4902 views)
Re: [jts1957] proscan psvr72 vcr - steps and procedure to replace idler assembly needed
Sorry to butt in, but let's make sure we need to get that complicated about it. The reason I say this is because idler assemblies have traditionally not required overly extensive disassembly to repair/replace, certainly nothing that should run the risk of throwing the gearing or timing off. I'm less familiar with your machine than jts appears to be, but I do know a lot of shortcuts and - perhaps more importantly - when not to get too crazy without closer analysis of the problem. If I may ask a few questions and get specific answers, I may be able to simplify things a bit: 1. Is the actual driving wheel on the idler a rubber tire, or plastic gear? 2. Does it look like something that is already turning should be driving the idler, either directly or indirectly - such as a belt from the drum or capstan motor? Or, is nothing turning at all? You should be able to visually follow the transfer of motion. For instance - if nothing at all is turning, you're looking at a different problem and it's not the idler. The video head drum should be spinning also. 3. If the pulley on the bottom of the idler IS turning but it's not driving the takeup reel, is there a lever or latch that looks like it should alter the idler's VERTICAL position that's not catching properly? 4. Does the machine fast forward and rewind properly? 5. Does it such the tape back into cartridge before ejecting? If you don't have a dummy tape, now's the time to make one. This will allow you to watch and even touch the idler in all modes, without the tape cartridge blocking your view of the action. A poor man's dummy tape is simply a VHS cartridge with all the tape and reels removed, and all the plastic cut out except a rectangular frame that is needed to make the machine think you're inserting a tape. You'll have to bkock the infrared LED in the center of the unit, which you can do with a small tab of electrical tape. Then the machine should go into all its functions, and you'll be able to really see what's happening or not happening. www.studiosoundelectronics.com has clear plastic dummy tapes which are much easier to use, if you don't feel like making one. Another nice thing about a dummy tape is that you can let it play and play while you press here and prod there, without continuing to spill tape all over the place. Sorry again about butting in; I just felt that conclusions were being jumped to, without enough information to be sure such extensive disassembly was necessary. Being able to see the problem from above, you might find something really easy and simple causing the trouble and not have to tear so deeply into the machine to fix it - possibly even the tape cartridge setting too low in the basket, and interfering with the idler's ability to pivot from left to right properly. Just for fun, try pressing on the cartridge and pulling it upwards while it's trying to play - if it starts working, you just saved yourself hours of frustration fixing the wrong thing! I would never even consider replacing any parts without first using a dummy tape and getting a good look at things from above. Both jts and I have helped other guys fix their VCR's in here, and we've both been wrong and we've both been right at different times, working from the few tidbits of information provided. . . . Barry Fone - VCR Repair hobbyist and professional FAA Repair Station Avionics Bench Technician (top level). TEST EQUIPMENT: (4) Sencore VC93 VCR Analyzers, (11) Tentel gauges, Sencore VA48 and (2) VA62 Video Analyzers, Sigma Electronics TSG-375 NTSC/SMPTE Video Generator, several VCR Alignment Tapes, plus countless Oscilloscopes, Frequency Counters, Wow and Flutter Meters, Distortion Analyzers, Vectorscope, 136-channel Logic Analyzer, Signature Analyzer . . . . VIDEO GEAR: (6) JVC BR-S822U's, (3) JVC BR-7000 series, (3) JVC BR-S500U, (2) JVC BR-S800U, JVC GR-800U and (2) GR-860U Editing Controllers, Sony FXE-100 Video Switcher/Effects Generator, (5) Time Code Generator/Readers, (1) Sony SLO-1800 (Beta), (2) Alesis ADAT-XT, (1) Sony DXC-1200 TV Camera, Pioneer VP-1000 Laser Disc Player plus many consumer grade Beta and VHS VCR's. Passionate electronics enthusiast since 1973...most anything except computers. Check out my collection at www.barrys8trackrepair.com/MyVideoGear.html
