rfitts46
Feb 14, 2018, 4:37 PM
Post #5 of 55
(8296 views)
Re: [jts1957] Sharp Aquous LC46D64U blinking green power light
The previous owner mentioned that a couple years back the main board was replaced. Looking at the shield hardware I see one screw missing and an incorrect screw used as well. Will remove cover on main board and check all connections. Before I go off on to the inverter boards will focus on the power supply board first. when the tv gets reset and the green power led is solid, will measure the outputs of the power supply board. interested in the two 60VDC outputs to the inverter board and a 5V output required for standby that I read about somewhere? Shouldn't the tv go into standby when it powers off and a red led is exhibited? Am aware of the electrolytics, transformers, bulb connections, and bulbs.
(This post was edited by rfitts46 on Feb 14, 2018, 4:43 PM)
