Mar 20, 2012, 11:55 PM
Post #18 of 32
(4647 views)
Re: [ajcrm125] Bridge rectifier putting out approx 170VDC?
ajcrm125;..... mel may be right.... But , I'm going to let that slide for now as subs have a tendency to not be the same as the original.... The 121-01167-01 OR TZ1167-01 may have the resistor & may be OK... The collector readings you gave seem OK... Time will tell... In case you are wondering why I did not reply , this is the reason;=>... Then , plug the TV in , turn it on & read the +dc volts from pin 1 on the flyback to chassis ground... Expect to get 130 vdc... When I get that info , I'll proceed.... THANKS........ Later...Ron.M........ Veteran & Retired TV technician
(This post was edited by Ron.M on Mar 21, 2012, 7:55 PM)
