Oct 22, 2014, 3:57 AM
Post #25 of 76
(3859 views)
Re: [VanBuren] Buzzing Voltage Regulator
Numbers on white sticker by rear jack pack? Is there any chassis or other number that has not already been mentioned? Serial number I don't need. The only schematics I can find for YOUR set are NOT free and 'I' don't pay for service literature. No item I mention is 100% guaranteed to be the actual bad part. They are only likely suspects. Bear in mind that I am using a schematic that is NOT for your EXACT model. It does use the IC and transistor you mentioned, and from other items I can see in your pictures, I believe I have a reasonably similar electrical match. However, the physical positioning of many items leaves a bit to be desired. I am assuming if I mention a item's part number, location number, etc, and it doesn't match what you have in front of you that you would be bringing it to my attention. Now as to where C507 is located, I CAN only tell you the points it connects to. It should be a 220ufd probably 25 to 50 volt electrolytic. The positive lead should connect to IC501 pin #13; the negative lead should connect to pin #9. FTF (Follow The Foil). ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Oct 22, 2014, 4:03 AM)
