Megatron
Apr 21, 2018, 12:45 AM
Post #42 of 56
(1615 views)
Re: [Megatron] CRT Panasonic TX-36PG50D tickting noise but not from relay
Diodes D2306 and D2715 MA29Q-A are fine, came new from China and act the same way as my old diodes. I have repleaced burned resistors such wire resistor R950 330 ohm on CRT L board, burned carbon composite resistors on DF board R527 220k ohm, R531 330k ohm. Then I have turned on the TV the TV worked normaly, I made check diagnose and still writes DOLBY not OK. I turned TV off and when I wanted to turn on the TV again the TV turns on for one second and goes back to stand by mode with red LED 3 blinking code. I can't believe it! I have measured voltages within 1 second before TV goes in safety stand by blinking LED mode. On D board: connector D1: Pin 1 7,5V (7,5V) OK Pin 2 7,5V (7,5V) OK Pin 11, 12, 13 -20V (measured -26V)(STB 6mV) Pin 14, 15, 16 +20V (measured 14V)(STB 0,6V) connector D2: Pin 6, 7, 8, 9, 10 15V (13V)(STB 0,6V) Pin 15 30V (30,8V)(STB 180mV) OK Pin 16 3,3V (3,4V)(STB 0,8V) OK connector D6: Pin 1 220V (230V)(STB 0,0mV) OK Pin 3 144V (can not measure jumping within 1 second)(STB 100mV) STB stand by mode. Sorry for delay the parts are arriveing over one month.
