Megatron
May 19, 2018, 7:54 PM
Post #51 of 56
(792 views)
Re: [Megatron] CRT Panasonic TX-36PG50D tickting noise but not from relay
I made a probe and connected to Computer speakers. I isolated the probe with two cheramic 10nF capacitors which isolate the probe not to allow current to go from TV PCB into Computer left and right speaker chanels and it Works much better then oscilloscope and now I can hear tone generator sound in Computer speakers. Finaly I found the problem and the problem is in chip IC2001, it doesn't output the tone generator sound on output pins R27, L28. When the sound appears on TV speakers then there is the tone signal on pins R27, L28. Before the IC2001 the signal goes First through IC3001 and it Works fine and the same whether the sound comes on TV speakers or not. Here are the results (AUDIO BLOCK DIAGRAM page 9) IC3001 16L YES 18R YES L52 YES R54 YES L38 NO (LOUD NOISE) R40 NO (LOUD NOISE) IC2001 (when sound appears) L56 YES R57 YES L53 NO (LOUD NOISE) R54 NO (LOUD NOISE) 25L H/P YES 24R H/P YES L47 H/P YES R48 H/P YES R27 YES L28 YES IC2001 (when no sound) L56 YES R57 YES L53 NO (LOUD NOISE) R54 NO (LOUD NOISE) 25L H/P NO 24R H/P NO L47 H/P NO R48 H/P NO R27 NO L28 NO H/P (Head Phones) The voltages in IC2001 are fine 8V (measured 7,8V) 5V (measured 5,02V). Maybe the problem could be on IC1107 which controlls digitaly via SCL, SDA IC2001, I don't Know. What do you think?
