Oct 8, 2011, 12:29 AM
Post #25 of 32
(5402 views)
Re: [t0nito] Help replacing tripler grundig CUC3400 including schematics
t0nito;.... OK , I REALLY need to have more coffee in the morning....... That red circled area IS the focus control.... IF that IS moving & you do NOT see ANY change in focus , sumptin's wrong... I know that was a stroke of genius to say... Also the HRT227BP & the HRT904 are VERY close electronically... The major differences being the internal resistors values... There is a BIG difference between the HRT227BP & HRT904... The HRT227BP has a divider value of 506 Megs.... The HRT904 has a divider value of 378 Megs... 506-378=128 Megs... I'm not sure that's the problem... But , that's a big difference... You STILL should see some change when you adjust the focus control... IF you see ZERO change in the focus , then one of 3 things is wrong... 1)..The trippler is wired in wrong... 2)...The trippler is defective... 3)..The trippler is the wrong one... Based on what you've just told me , it's wired in correctly so it's #2 or #3.. So I'd suggest you send that one back for a refund & get the one from here;=>...(Your link) http://www.hqelektronik.hu/info/en/hrt904.html They're in stock... Altho , I have NO clue what 4620.00 OR 3008.85 HUF's are !!! Thank God those are NOT USD or GBPs... The main reason I'm suggesting you get the HRT904 is that you presumeably had good focus before this problem...Correct ??? Another thing that is blowing my mind is how did you get from a HRT310 as is in the service manual to a HRT227BP OR a HRT904 !!! There is NO internal resistor for focus in that trippler (HRT310) , which indicates to me that there was at one time a resistor/control mounted somewhere onboard the chassis separate from the trippler... It apparently was removed when the current trippler (HRT904) was replaced... Sound logical ??? Hard to tell , but these pix appear to show a different trippler;=>... Don't see any adjustment , tho.... Have a GREAT day & weekend........ Later..Ron.M......... Veteran & Retired TV technician
(This post was edited by Ron.M on Oct 8, 2011, 12:30 AM)
