Feb 1, 2010, 3:16 AM
Post #6 of 30
(5252 views)
Re: [dohclude] Philips 55P8341A Convergence Problems
dohclude:... Thanks for hanging in there... OK , lets get started.... We need to remove the front screen & take a look down into each CRT lens while you have it on & with signal.... I reccommend the front because it will be easier to look down the lens to see the video... (If you need help with the front screen removal info , just ask & I will post instructions how to do that).... You will be looking at a bright pix so use care when you do this.... Start with the red as it usually is the best to use as a refference.... The red video should be bright , in focus & clear on the CRT screen.... Next look at the green CRT.... This video should be bright , in focus & clear also , but may have some clouding in the coolant... Now , look at the blue.... If I'm right , this one will be the worst of all... You probably will see a mess... Poor video , poor focus & lots of contamination in the coolant.... Post back with your observations... Thanks.... Later...Ron.M........ Veteran & Retired TV technician
(This post was edited by Ron.M on Feb 1, 2010, 3:20 AM)
