Jul 26, 2009, 8:01 PM
Post #3 of 39
(10064 views)
Re: [winard] Philips TV repair questions
winard;..... Try this:...1st,KILL the cat!!!......Just kidding.... should I even try to repair it? Your call,depends on your background,TV / electronics experience,etc... Seriously,try this:... Remove CAREFULLY the back cover... You need to locate the flyback.... It will have a large red wire coming from the top & 2 adjustments on the side.... That red wire has 30,000 volts on it when the set is on & will hold that voltage for quite awhile even when the set is OFF!.. USE EXTREME CARE when you do this... KEEP your hands AWAY from that red wire when the set is ON!!! On the side of the flyback there's 2 adjustments... The top one is for "focus", self explanitory,for a sharp & clear pix... The one under focus is "screen"..... This is the one you are going to adjust... With the set up & running,adjust the "screen" control just a tiny bit counter-clockwise... You may see a slight reduction in overall brightness.... The faint green tinted lines that stretch horizontally across the screen only visible in dark scenes should dissappear.... IF not turn the "screen" control just a bit more.... Do NOT repeat a 3rd time... The other possibility is that the CRT has an intermittent short... This can be solved with an isolation transformer that can be had for about $12-$15 + S&H.... They're not hard to install & I can help you out if need be.... In reply:==> When it turns on it usually flashes a lot of green, resembling a rave lightshow or something, then after 10-15 seconds the picture will come up and work fine until the TV is turned off. This "could" be the CRT (Pix Tube)...We'll worry about that later.. After it's off it will not come on again until it is unplugged for a few hours. Fail safe/protect circuits are kicking in...Normal,when there's a problem with certain circuits... If the TV has not been unplugged it will sound like it powers up, but will not light up and the led will blink a seemingly random pattern that seems something like morse code with long and short flashes. It IS a code from the microprocessor's self diagnostics telling us what it found wrong.... We may need you to "de-code" the flashes for further help.... It is NOT a random pattern,but a sequence of numbered flashes we use to identify which circuit has problems.... When you unplug the TV , the micro resets itself & the TV now thinks there's no problem til you turn it on again...NOT to worry at this time.... Finally for now:.... Depending where the cat peed "may" be a fixable problem.... Your TV is NOT "finished" from what I determined from your post!!!! It appears to me that due to the "green" problem is why you got the set in the 1st place... IF you are uncomfortable doing ANY of this , PLEASE let me/us know....OK.... GOOD LUCK & STAY SAFE.... Later....Ron.M......... Veteran & Retired TV technician
