brrazap;....
It appears that you may have either a bad blue CRT board or bad connections on the board....
Lets try the easy way first....
Since you told me that you can solder very well , here goes....
Your best way to do this is to remove the blue board by disconnecting all the wiring that goes to it & take it out of the set....
If you can't fully remove it , find a way to stabilize the board while you resolder the connections....
Check all the connections for a cracked circle around the connection...Especially the CRT socket....
If you have any doubts about whether or not it's good , solder it anyway...Better safe than sorry....
You have what appears to be a 16 pin IC on that board...Use care if/when you solder those pins....
They are very small connections & very close together making it easy to have solder bridges develop & cause short circuits which can cause damage when you turn on the TV....So BE careful !!!
Lert us know the results....
Lateer...Ron.M....
