May 7, 2012, 7:26 PM
Post #11 of 34
(4246 views)
Re: [mike03] toshiba white horizontal line and intermittent audio
Mike03 OK 8.2 ohms is shown as an alternate for R327 so we are good there. The schematic also shows an alternative of R101 attached to the hot side of F470 or the down side. If attached to the hot side, pull the fuse and check the voltage across C101 for 33 volts. If attached to the downside, make sure that the fuse is not open. Also check R470 for .75 ohm 2 watt for ohms and solder joints. The fact that it fires up and then shuts down puzzles me. Post back with what you find. Ron If it helps, the chassis is TAC 9500 or TAC 9501. It applies to model number CF13E22/23, CF19E22, CF20E26, and CL14E26
