Jun 30, 2012, 7:40 PM
Post #33 of 34
(948 views)
Re: [mike03] toshiba white horizontal line and intermittent audio
OK it has been so long and so many posts, let's start from the beginning. First, did you put the fuse F470 back in? Check the voltage across C884 (115 vdc), C448 (115 vdc) and C101 (33 vdc). Again, take the measurements before the set shuts down. Take them again after shutdown. Don't worry about the line not coming up because hopefully, we have solved the vertical deflection problem and you should have full screen which may not come before the set shuts down.
