Nov 22, 2009, 11:22 PM
Post #14 of 27
(6205 views)
Re: [Tiger Mimi] RCA VBT501 1980 needs a lil' help
*```````````````````````````````* (Ignore all of the: ```) ``* * * * * * * * * * * * * * * * * ```````<<< >>> *```````````````````````````````* The foil pattern (on the PC board) for switch will look something like the above. It will be a long (2-3") metal, squared-off, "u" with a plastic stem aticking out either end and can slide (in the direction of arrows) and then return to starting position (spring loaded). The other piece I believe belongs on the "basket," (tape hold fasts?) keeps the tape from sliding easily backwards (as holder is lowered into mechanism) once tape is slid into tape basket. ------------------------- Location: Far, Far Away
