Barry777
Jan 18, 2010, 1:20 PM
Post #27 of 27
(1572 views)
Re: [Tiger Mimi] RCA VBT501 1980 needs a lil' help
Sounds like the most likely source of the squeak would be the reels - remove their retaining rings, pull them off and shoot a drop or two of OIL onto the spindles (not WD-40, as it's too light of a lubricant). Be sure not to lose any of the spacer washers under the reels; they are there to set the correct height of the tape cartridge reels which is extremely critical. Could also be coming from the capstan if the squeak only occurs in Play mode - or many other places too. To lube the capstan, lift up the oil-retaining plastic washer a quarter inch, apply one drop of oil around the capstan shaft, then push the washer back down. Make sure to use alcohol or acetone to remove any oil above the washer, or you're looking at damaging the first few tapes played after this operation. . . . Barry Fone - VCR Repair hobbyist and professional FAA Repair Station Avionics Bench Technician (top level). TEST EQUIPMENT: (4) Sencore VC93 VCR Analyzers, (11) Tentel gauges, Sencore VA48 and (2) VA62 Video Analyzers, Sigma Electronics TSG-375 NTSC/SMPTE Video Generator, several VCR Alignment Tapes, plus countless Oscilloscopes, Frequency Counters, Wow and Flutter Meters, Distortion Analyzers, Vectorscope, 136-channel Logic Analyzer, Signature Analyzer . . . . VIDEO GEAR: (6) JVC BR-S822U's, (3) JVC BR-7000 series, (3) JVC BR-S500U, (2) JVC BR-S800U, JVC GR-800U and (2) GR-860U Editing Controllers, Sony FXE-100 Video Switcher/Effects Generator, (5) Time Code Generator/Readers, (1) Sony SLO-1800 (Beta), (2) Alesis ADAT-XT, (1) Sony DXC-1200 TV Camera, Pioneer VP-1000 Laser Disc Player plus many consumer grade Beta and VHS VCR's. Passionate electronics enthusiast since 1973...most anything except computers. Check out my collection at www.barrys8trackrepair.com/MyVideoGear.html
