Centaurette
Mar 2, 2011, 3:54 PM
Post #64 of 66
(4853 views)
Re: [Ron.M] Panasonic PT53WX53 geometry off
I need the number off the remote or a pix.... It's EUR7603Z9A
Do you just use the TV ONLY on Direct TV or other inputs ??? By this, do you mean do I have just satellite or do I have other means like cable? Or do you mean do I only use the TV to watch TV or do I have a gaming systems and/or a DVD or VCR?
Is the pix cut off on ALL modes & during ALL inputs ??? The pix is cut off in all modes...Zoom, Full, Adjust, and 4:3 modes. The pix doesn't seem to change at all in Full, Zoom, or Just modes. And it was the same regardless of what external component was used...Wii, DVD/VCR combo, PS2.
WHERE did you find this at & how did you adjust it ???? First, I had to change the Aspect via the remote to Zoom. Then using the front panel on the TV, hit Menu. I go into Setup, Other Adj, then Zoom Adjust. The choices within that are Size (can only choose 0-4), V-Position (which can only be used if Size is 1 or higher), and Normal...which is a matter of Yes or No.
Are you using a DVD player or did you mean "Closed Caption" ???? I mean when using the DVD player or watching TV...like when they do translations within the TV show. I don't remember what you said that triggered this thought, but I'm going to check my Directv remote. I know there's a Setup section in the Menu, but if I recall correctly, there wasn't anything to change the TV ratio or resolutions. Since that is a nagging feeling I can't get rid of now, I'm going to check my Directv remote and see if I might've missed something in the Setup Menu. I will get back to you in a little bit. I have to try to get a compromise from my 4yo daughter to be able to steal the TV from her for a few minutes.
