Jan 31, 2011, 6:50 PM
Post #5 of 66
(9935 views)
Re: [mjbxx] Panasonic PT53WX53 geometry off
mjbxx;.... Only problem, its in a compressed zipped file format which would make it impossible for you to read if I emailed it to you. Where did you ever get that idea ???? Compressed zipped files are easy to open & use if you have the right program to unzip , such as 7-Zip or WinRar (?).... How big a file is it (MBs) ???? When you open & use yours , is it ALL in one pdf package or separate pages broken up into little packets ????... I am curious as to what your first impressions regarding the picture in my first post. The picture seems OK but is tilted on the display. It's a bit difficult , if not impossible , to see the tilt you refer to in the pix.... We'll deal with that later.... The list you have does not help me much... The adjustment I'm looking for isn't there.... IF I had the manual , I may be able to find it.... Most of those adjustments listed have to do with basic positioning , size & proportionment.... NOT the "tilt" adjustments I need to find & see IF this model has them electronic or mechanical..... As far as transfering the manual goes , have you heard of OpenDrive.com ( https://www.opendrive.com/index.php?b=b ) that used to be boxstr.com... You can upload files , pass the link to me & I can download the file.... BTW , it's FREE.... Check into it.... Let me know.... Later....Ron.M......... Veteran & Retired TV technician
