Jun 28, 2009, 10:38 PM
Post #15 of 57
(3198 views)
Re: [Astrovel] Is my TV bad? or is it my antenna?
Astrovel:.... If I could post a picture on here, I could show you the map which I already printed out a few days ago from antennaweb.com. It shows both A (4.1,5.1,8.1,11.1,13.1,21.1,23.1,40.1,52.1) and B (2.1,27.1,33.1,49.1,68.1) in a V back to my location. That's NOT the info I wanted....Here's what I NEED!!! ==> Click on "Submit".... Scroll down & you will see a list of all the channels in your area + which band they're on , how far to the stations antenna , their broadcast location , etc... Check out where 8 (I'm guessing that's ABC in your area) & 11 (I'm guessing that would be CBS in your area) are NOW broadcasting...Here's how... Look under the "Network" heading for ABC & CBS & maybe PBS.... Then go over to "RF Channel" column... <<<===THIS IS WHAT I'M LOOKING FOR!!!!...FOR # 8 & 11...(ABC & CBS ??) Write that info down..... The map is for YOUR benefet when you repair the antenna....(Sorry, the bold type will not turn off, NOT my fault.) By the looks of things , you have 6 VHF channels in your area... Please update the info on channels 8 & 11 for me....Thanks... Also:""PS: Did they come out & look at your antenna??? "" Thank you.....I'm pretty sure I have an idea what's going on here.... After you answer the above I'll post my suspicions... FYI:... Like you, I'm retired & not making ends meet with those "wunnerful" Soc Sec checks...So I watch my pennies VERY closely.... Later....Ron.M......... Veteran & Retired TV technician
