Aug 27, 2010, 5:53 PM
Post #53 of 57
(770 views)
Re: Is my TV bad? or is it my antenna?
boy2suk & techcris;.... Both of you guys need to learn how to read........ This thread is over a year old.... For the most part , dead....... boy2suk;..... When the tekkie from bestbuy will come around, im sure that he'll focus his workon the audio amplifer section of your TV and finally he 'll fix it. that is my method if i were to repair TV of the same symptom.... IF you'd have read this thread fully , you'd have seen that happened in post #41 where the guy from BestBuy said she may need a couple of boards.... More than likely , that problem IS solved.... Thanks , Genius , for that Long Overdue advice.... techcris;.... 13 months wait for a service call is a bit slow even by best buy standards See post #41 dated July , 4th , 2009 !!!!... That's 13 MONTHS AGO !!!!.... The rest of this thread deals with an antenna/reception problem that may/may not be solved.... Later....Ron.M......... Veteran & Retired TV technician
