samuelsteven
Jan 4, 2009, 1:28 AM
Post #11 of 62
(23877 views)
Re: [Paulpablo] Polaroid FLM-3232 no power
There may be more then a few, you can tell by the 4th and 5th characters of the serial number. for example the 4th and 5th of mines are 00, some are C1 and A6, these all use different power boards. The one u worked on might have been a C1 through C6 or an A6. You said that the picture i posted was not the power board, when in fact it is. Heres a link to the C1's board http://cgi.ebay.com/...ksid=p3286.m20.l1116 As you can see its also an FLM-3232, but not the same board because its for a different revision or "model version" if you will. So, the capacitors you found bad on that tv, probably was not the same version as mines. If anybody can assist me, it would be very appreciated.
