Dec 7, 2010, 4:47 AM
Post #16 of 65
(28668 views)
Re: [Uzail] Sanyo tv won't turn on
Uzail;..... How do I post pictures? I'll simplify this..... 1st , take a GOOD pix with your camera.... Upload it (them) to your computer.... Save it as a JPEG...... Save it to your desktop.... Give it a name so you can find it easily.... Go to http://imageshack.us/ or http://register.photobucket.com/step1 & sign up & join.... They are both FREE to join & use.... Upload your pix.... Select a proper sized pix or enlarge it.... Hover your mouse over the pix & right click..... Select "copy".... Come back here & paste your pix in your post.... I suggest you use imageshack as it is easier.... When posting a pix from imageshack.us do this;... Select the pix you want to post from "My Images".... Right click on the image you want to post.... A box with several choices will appear.... Choose "View Image".... When that window opens , right click your mouse anywhere in the pix to get "copy" up in another set of options... Click on "copy"... Come back to the box you are posting in , right click "paste" & Ta-Da , your pix shouild pop up full sized & clear as it was taken... Before you post the pix in the thread , go to the "Preview Post" button at the bottom center where you are making your post & click on that one time.... Wait for it to load the post... Scroll up & check your post & pix... If the pix is too small or too big , go back to imageshack (or photobucket) & make the needed adjustments.... If you need any further help or info , just post.... Also , remove the HOT from the set.... Use a solder-wick to unsolder it.... If you dont have it , get it as you will need it in the future.... The HOT has one small screw at the top center holding it to the heat sink with a small nut & washer.... Use a pair of needle nosed pliers to grab & hold the nut.... Re-check it using ohms.... Put one lead on the center pin to either one of the outside pins... Take reading..... Also , take a reading from the center HOT pin connection on the chassis to ground.... Post info.... Later....Ron.M........ Veteran & Retired TV technician
