Dec 17, 2010, 8:24 PM
Post #64 of 65
(3408 views)
Re: [Uzail] Sanyo tv won't turn on
Uzail;..... Time for me to say goodbye.... You & I are having a communication problem that is not getting any better... I asked for some simple readings that should have appeared something like this.... HOT , plugged in;130 vdc or ??? HOT , set turned on : 130 vdc or ??? Q401; Base , set off, X vdc Base , set turned on , X vdc Collector , set off , X vdc Collector , set turned on , X vdc IC101;set on.... Pin 21 , X vdc Pin 23 , X vdc Pin 26 , X vdc... Instead , after 3 days of asking & explaining , I get a LONG list of numbers I'm going have to ask someone else to translate into working numbers.... NOT going to happen.... It's painfully apparent that you severely lack basic electronic &/or TV repair knowledge.... That complicates matters... You basically appear to be a nice , sincere person.... Do NOT take what I said as a personal attack.... It is NOT meant that way... It's just that after a given length of time & effort , there comes a time to make a sane decision.... Someone else may come along & help you.... I wish you the best....... BTW: I deleted posts 5 & 7 that had "Listen up" in them.... Might make things easier for you.... Good Luck.......... Later....Ron.M........ Veteran & Retired TV technician
