Jul 16, 2009, 2:22 AM
Post #4 of 100
(13625 views)
Re: [D-Rock3] Im in desperate need of help
D-Rock3:.... I stole the following posts from another website;==> 1st post:... May 1, 2009 3:34 PM First i would like to thank you for you're fast reply. The set started acting up at first you could power it on every thing would be fine then it would shut its self off aprox 10 - 15 min later. now if you press the power button it will start to power on but shut off after aprox 5 seconds. I have been looking online for replacemnet boards and from what the tech said is everybody is having problems getting parts from rca and they no longer make it. 2nd post:... May 1, 2009 3:39 PM That chassis is famous for needing CP150 and CP114 replaced along with possibly the flyback. The good thing is that You can get the parts at the following link with free instructions. http://servicemanuals.vstore.ca/ First though I would just recomend reflowing the solder on the flyback. If you send me a email to (deleted for privacy reasons) I will send you the instructions on how to remove the deflection board and show you where the flyback is, as it may correct the issue just by resoldering the flyback connections. _______________________________________________________________________________ D-Rock3:...These 2 posts are for your exact TV.....GOOD luck........... jts1957:.... What's that prove. I've got one desolder/soldering station, numerous pencil-type solder irons of many wattages, and a solder gun, but I still can only use one at a time. Come on now....The guy was just trying to give us some of his background experience etc , & you reply with that???....Be nice , girl, he needs our help....OK??.......... Later folks....Ron.M.......... Veteran & Retired TV technician
