We need to see if you have ANY deflection at all....
1st we'll check out the vertical....
Then we'll check for High Voltage...
I'll need a couple of pix....
One of the flyback area....
The 2nd is where the Vertical output (Pin # 5 ) connects to the
yoke connector....I need top views of both...
I managed to find a service manual for your TV....Sorry , its NOT free....
It's a downloadable file & costs $15.99...
Here's the link:....
http://www.servicemanuals.net/...74/pos1/results.aspx IF you decide to get it,do so at your own risk as I have NO
experience with that company....
IF you do ,get the version for
R52WH74YX38 <<<(Acts as a DIRECT link) as I think it's the right
one....
If the "YX38" is not on the label on your set,don't worry about it....It's STILL a ITC222A chassis....
IF & when you do,I will need to see it...So that means you will have to email or PM it to me....
As usual , Your call....
Let me know what you decide to do....OK....
Good Luck....
Later...Ron.M....
