Oct 13, 2009, 4:56 AM
Post #93 of 100
(6454 views)
Re: [D-Rock3] Im in desperate need of help
D-Rock3;.... GREAT to see ya !!! Mr computer whiz:...I have another glitch!!! When I first extracted the files , ALL the sub-files had a Foxit graphic...And I could easily open them .... Now after I closed my desktop down to PM you , I got a surprise when I returned.... ALL the Alignment items do have the Foxit graphic & I can open them fine.... HOWEVER !!!...The schematics section is screwed up....73_CRT is the ONLY file that has the Foxit graphic & I can open it fine.... MOST of the rest are VERY pale washed out images of schematics that I can NOT open !!!!...I've tried Foxit & Adobe...Foxit says it needs a PDF converter which I can not get...Fails to install....Adobe gives a message that the file is dammaged (Which it's NOT) & it's a jpg...Clicking on properties for those files show them as "JPEG"..... There are 11 "ADMI" boxes that are totally black !!! Also shown as JPEG & will not open up....One is a "SWF" file....One has the "Opera" browser graphic & opens up a webpage....Cute !!! What I've just discovered is that when I extract them again the Foxit graphic appears momentarily & then quickly dissappears to those washed out images.... What I need is to be able to open the file , copy & paste parts of it to help you out.... Adobe & Foxit are not allowing me to open the files or copy & paste..... I now have WinZip installed...I "may" not be extracting them correctly....PM me with detailed info as to extract... Any other ideas ???? Later...Ron.M......... Veteran & Retired TV technician
(This post was edited by Ron.M on Oct 13, 2009, 4:56 AM)
